Is my washer drain unsafe?
Joecoolaug
Jun 9, 2018
Hi, I've been reading up on drainage systems, and I'm beginning to worry our washer drain is vented to our basement.
The washer drains directly to a large utility sink, which has a p-trap then drains to the house's main out line. However, just downstream of the p-trap (connecting to the drain in a wye) is what appears to be a standpipe open to air. There is no trap below it - it appears to vent directly from the sewer line.
I'm not especially familiar with plumbing, so I googled everything I could on the subject. I couldn't find anything that would explain this. Is my basement open to sewer fumes?
Thanks for the help.
    1.3 MB
    1.3 MB
yes you are probably smelling sewer gas... it should be connected to the vent system in that are if that's not possible there is a fitting a mechanical vent fitting you can install but the best way is connecting to the plumbing vent system
