duet12
Hi, I DIY water softener myself and have a question.
The drain water out of water softener is through a barb head with a hose. The hose is supposed to drain the water to a waste drain pan. I have a pre-plumb copper pipe which is connected to drain pan. So I am trying to hook the hose to the copper pipe.
To connect the hose to copper pipe, I again use a barb head. So now the hose has two barb heads on the two sides, one side out of water softener, the other side is to drain copper pipe.
I found out later, the hose is always full of water. I am afraid that the barb head is only one way, so the water can't actually drain to the copper pipe.
Is my worries valid? Is barb head only one-way?
Best
Duet12
Best
Duet12
