Thanks. Tried to search for info, but perhaps too general to get an answer.
I have a home where I tore out an old deck. There is a steel gas pipe coming from underground by one side of the former deck and it appears to have a green coating on it. It is around 1.5 or 1.75" and runs about 20 ft then turns and goes 4 ft then has an inline valve, then a 'fitting' then an elbow then goes through concrete to the crawl space. I'm thinking the 'fitting' must be some sort of reverse threaded on one side else I'm not sure how one would remove the assembly.
Here is a link to some photos.
https://plus.google.com/110308938275594273789/posts/Nk5AjoHYvki
Just want to do a safe job of replacement prior to deck rebuild. Is really rusty. I have some big pipe wrenches but haven't tackled something like this.
Is there an adapter from steel to some sort of plastic gas pipe that would work? Don't want future corrosion if possible.
Ideas? Thank you!
Ideas? Thank you!
