Kestralyn
I’m replacing the faucet, drain, water lines, and p-trap on the pedestal sink in my downstairs half-bath. I’ve been successful with the faucet, water lines, and p-trap, but the drain is fighting me and I could use some advice.
The drain is a Pfister Push & Seal that came with the faucet I installed. I’ve followed the instructions to the letter - at least five times, in fact. I can’t seem to form a seal between the drain and the sink. I get everything tightened up and when I test it, I get the same result every time: substantial leak from the drain hole. I’m not sure if it’s because my “hand tight” isn’t as tight as it needs to be, or if the sink (older, unknown maker) has too large a drain hole, or... ?
Do you have any suggestions, advice, etc. for this problem? I appreciate any assistance you can offer!
(Sorry for the long explanation. I don’t know the terminology well enough to make this any shorter.)
