rustyadams_99
I am installing a Tile Ready shower base with an attached drain that will adapt to a 2" PVC pipe I have installed. I have tried setting the base over the pipe and it is a little snug so I would like to be able to pull the pipe into the drain fitting from above but am not sure if there is a tool designed to do this or not.
There is no access to the drain from below so it needs to happen above. Any suggestions are welcome.
