Hello, thank you for letting me register for this forum.
We have moved into a new house and once we started using the facilities a sewer gas smell became apparent in the laundry area. Blocking off the washing machine drain eliminated the odor. Using a snake and a remote camera I was able to determine that there is no trap in the washing machine drain. I've done a lot of DIY plumbing, but I am uncertain of how to fix this. I can put a trap in the wall, but the problem is that there is not enough room for a proper P trap. The drain line is straight down from the washer wall insert to the floor. Like this illustration. The left and right lines being the wall studs
The option I was trying to go with is this illustration, but it ends up basically being an S trap that I would like to avoid if possible.
The pipe is 2" PVC and there is no room to place a lateral span of any sufficient length between the trap and the drain into the floor.
I have seen the straight thru trap assemblies on various web pages, but I have been unable to find a source in the U.S. and those I did see are not 2". I was hoping someone with more experience might have a suggestion for me.
Thanks,
Brent.
Thanks,
Brent.
