Hello everyone.
Recently I've noticed that when I turn on the water in my house hot or cold the pressure is initially high for about five seconds or so then drops back down to normal. I bought a pressure gauge and screwed it onto the hot water side of the washing machine hose bib. My house pressure is about 50 psi and about 45 psi when using water. After I use hot water the pressure gauge slowly rises to 80 psi. If I open the hot or cold water pressure drops back down to normal and remains steady. If I turn the hot water tank off and use hot water afterwards the pressure remains at 50. I've searched many forums and the consensus seems to be to install an expansion tank. My issue with this is I have never had this problem before it just started happening. About six years ago I had a new hot water tank and PRV valve installed in the house and no issues until now.
Any help would be appreciated before I start making changes.
