I have a Buderus ST150/2 off my gas boiler. I came home today and found about 10+ gallons of water on the floor and the PRV was still leaking. I shut off the supply to the heater and shut off the boiler.
I turned it back on about 30 minutes later and within 10 minutes it started leaking again pretty good from the relief valve.
I suspect it's either the thermostat or the pressure relief tank gone bad... Anyone with experience have any thoughts? I feel like it may be too much water to be the Pressure Relief Tank, but thats a cheap solution to try!
