Incorporating a new Elec HW tank to current coil/oil furnace
cbliss01
Jan 8, 2018
I'd like to install a new Electric hot water heater and to keep my current water heating system in the case that I need it as a back up. The current system is a oil burner with an internal coil for the water to pass thru to heat, then the water goes to a mixture control valve etc.
Is it possible for me to plumb in an electric hot water tank into the current system by using shut off valves and TEE connections?
or is this a not-so-good idea?
Any advice is appreciated. Thank you in advance.
You could do that. Just bypass your coil install some isolation valves and hook up to the cold feed and hot outlet. Then disable your low limit on your boiler, so its not staying warm to heat the coil.
Thank you for the reply! I may use a tankless heater instead of a traditional electric water heater. The bypass should still work correct?
im thinking of doing that in my house already ran electfrom panel have tees on the hot and cold just need the time ….my tankless never runs out of hot water
