in order to install a shut off valve, in the photo on left, it would be that pipe connection area located over upper left part of the photo?There should be but it’s not.
To install stop valves you would remove the fip x compression 90’s that turn and transition to smaller tubing and then install FIP x compression angle stops.in order to install a shut off valve, in the photo on left, it would be that pipe connection area located over upper left part of the photo?
