How to repair leaky cooper pipe
bennyhill007
Nov 3, 2016
Need help in how best to repair leaky cooper pipe. Water is leaking out of the upper joint (red arrows). Thanks
I recommend you replace that old gate valve with a ball valve, while you are there,
1-turn water off from meter
2-cut off gate valve
3-unsolder the tee from the nipple coming out the wall.
4 solder nipple under ball valve, ball valve m,then small nipple on top of valve
5- measure to nipple on top of ball valve, to bottom nipple out the wall
6-slide slip coupling over nipple on top of ball valve, (mark 1/2" away
) to know when you're in middle
7-solder tee and slide coupling up to solder
8-add adaptor to add hose bib ,
9-wipe it all down,
10-turn water back on SLOWELY and hope for the best
11-either open a beer and celebrate or open a yellow book and call a plumber
Well I think Cooper should see the doctor if he has a leak.
Best bet is to cut everything out and replace it with new copper
