If I don't get an answer here, then I will. Thanks.bring this pic to a PLUMBING SUPPLY HOUSE they may be able to identify and help you out unless someone here knows
Hi Paul, please see attached. It would go as far as this. Any suggestions? ThanksThe faucet should have a small Allen screw on the underneath near the wall. The handle should unscrew and you can remove the face plate afterwards.
Sorry, I misled you guys. Indeed there is a screw under the handle. But it was under some residue and was impossible to see, it blended in. So I removed the screw, but knob (or how you call it) wouldn't come off. What usually happens? It should come off easily? I am afraid to pull it hard. But if it should, I will pull it harder. Or should it twist off? Also afraid to twist it off harder.Is there a screw or allen screw where the handle was removed
