So I digged the soil for half a feet and found where the leak is. It is the distribution center of sprinkler system where it is connected to controller with wires and pipes.
I immediately saw where the leak is. So I bought the primer and the other liquid I forgot the name. These are for PVC cement.
I placed both liquids on both ends of the pipes inside and out. Then I manually attached them. Waited for couple of minutes. Release it. And it holds perfectly.
But when I turn on the water, it cracks from the another connection. If I fix this new one also, the previous one starts to leak. So I was not successful in fixing this issue.
Yesterday I saw a handyman working on my neighbor's sprinkler system, I called him over to give me estimate. He looks at the pipes in 1 second he says "oh you can NOT use pvc cement on old pipes, it will not work".
So he says I need to buy new pipes and install it.
Anyway, back home where I came from (eastern Europe) there is a pipe melter gun. You melt both ends of the PVC and before they get cold you connect them and viola, it freezes and you get one piece pipe FOREVER.
Is this solution available in USA?
