Jeffress77
So we just bought this house about 8 months ago, and this is a Vaughn 80gal. electric water heater. The tank has a “cold water diffuser”. The cold water supply inlet for the unit is at the bottom, and evidently this doubles as the tank drain as well?
I want to flush/drain the tank but man, I am confused here.
I shut off the power going to the unit. Then I wanted to keep the cold water pressurized to flush the tank rather than just simply drain it because I fear there will be lots of sediment. However I don’t know if that’s possible.
I attempted to simply open the drain valve at bottom, but only achieved cold water draining (obviously since there was full pressure from cold water supply. So then I shut off the cold water supply ball valve, and opened the drain and it trickled to stop almost immediately. So then I thought I’d go to the upper level of the house and open the hot valve in the bathtub, while keeping the tank drain open. That didn’t achieve any results either, really.
So here I am… how to get the water/sediment out of the tank when cold water supply inlet doubles as the drain??
Thanks in advance!
Photos attached
Thanks in advance!
Photos attached
