Started this thread so I could find it agian.
This is how I cut out and repaired cast iron santee in a wall with a metal cut off blade in a 4-1/2" grinder.
http://www.plumbingforums.com/forum...-line-water-crawl-space-oh-my-1955/#post21200
You most likely have a broken drain inside the wall.
Do you have cast Iron drain system or plastic(PVC or ABS).
I just made a similar repair a few months back.
Not for the DIYer unless you are particularly very handy at fixing things.
The one I fixed was the steel vent had rotted out just above where the kitchen drain goes into the wall.
I have pictures of how I cut it out and repaired it.
I might have already posted them here somewhere but I'll have to go look and see.
Open the wall under the sink to see if it's broken.
Take some pictures if you can. It will help a lot. Or Call a Pro and let them do it.
