Hi, I am planning to move the laundry to basement. I am planning to do it by myself but I don't really have much experience with plumbing. Below is the list of things needs to be done.
-Hot and cold water pipes needs to be extended 10-15 feet from the ceiling and down the wall where washer will be.
-A laundry sink will be installed.
-Sewer line is above the sink and I need a pump under the sink to be hooked up to the sewer line which is right above the sink.
-I also would like to change the water heater (50gal)
Any advice if I should do this by myself or how much would it cost if I hire a plumber. We live in Michigan
Thanks for your comments/advice
