How do I deal with a leak coming from the bottom of this elbow?
Thank you for the reply.
The 1-1/2" lines won't be difficult, but what about the bottom? There are two 45 deg elbows attached directly to each other and then they turn into the slab no more than 1/2" above the slab. (see new photo)
I can remove the base board (I'm going to have to do that, anyway.) if you need a better viewing angle. I didn't expect to have so many connectors jammed together with no room to patch.
Oh, and I piled on a bunch of old plumber's putty I had sitting around. That's just a temporary patch and not intended to be a repair.
What do you think I can do about those elbows?
LOL...That my friend, is where experience and training come into the equation.
I know how to remove that fitting from the other fitting, it is not something that is taught over the internet
because the first time you attempt it, you will screw it up. called a learning curve
if you screw it up, you can try to do the same on the other end of that fitting.
if you screw that up. you will be busting concrete
and if you screw it up, Rent a chipping hammer and chip out the concrete from around the pipe going into the floor. Presuming you're on a slab
Thanks, guys. I'm going to order a ram bit and then be as careful as possible.
