ruyaguilar
So today I came down to the basement and noticed a small puddle of an oily liquid. When I looked up there was a black pipe. Based on the location and because is coming from the water heater I believe is a gas pipe that feed the kitchen burners. I noticed that the pipe was covered in this oily stuff and that the joist was also covered.
What is this? Should I be concerned? Should I replace the pipe? Is it due to condensation?
Pictures attached. Note that I covered the pipe with some foam insulation tu raise it and stop it from touching the joist directly. But the problem is there. You can see that the joist has oil.
Appreciate any help.
