Hello, I am having a problem with my hot water tank. Heres the story.
So a couple of years ago, our original hot water tank started leaking and cause a lot of trouble in out house so we replaced it with a new hot water tank. This hot water tank worked for maybe 1-2 years then started leaking from the pressure release valve. We called a plumber and he attached a big roundish thing to the top to collect the pressure or excess water something like that. This helped for another year or so but then the water came back again. So for about a year, we've been connecting a hose to the valve and put that to a drain so water won't go everywhere. A couple of days ago, i found out changing the pressure release valve might make the leaking stop. So I went out, bought a new one and changed it. A hour or so later, the water started leaking again. What are the possible problems of this and ways I can fix it. Help would be very much appreciated.
Thanks.
ps. the hot water tank is a electric one with valve on top. thanks
Thanks.
