waterstuff
Last week we had a pinhole leak in the supply line to the gas water heater. The plumber replaced the segment of the leaky copper pipe, the check valve, and a ball valve. All else remained the same. (the recirculating pump's flow speed, pump timer settings, and the water heater thermostat setting).
Now the hot water has become very slow to reach our faucets through the house. As if the pump is not working properly. But when I check the pump it seems to be spinning ok.
I've increased the pump speed, and the thermostat, but to no avail.
The WH and the pump are 8 years old. They were working fine before the pipe/valves replacement.
What could be the problem?
