sportykev
Hello,
First time member, first post, hoping for a helping hand.
We just started experiencing the sound of water running behind the shower on the top floor. There is no indication of a leak. But I have a theory (without fully understanding how the hot/cold valves work), but please hear me out. This noise stops if I shut the hot water line coming from the hot water heater.
We have a Moen single handle shower faucet. I was thinking to 'bleed' the hot water lines by shutting off the cold water intake into the hot water heater while leaving the hot water line open. I then opened all the faucets in the house to hot to allow for the pressure to be released, and have all the hot water go back to the basement exiting the slop sink.
There is one problem, the shower (top floor) where we hear water constantly flowing, has a constant trickle of water coming out, and it's cold. No hot water exiting. Does this indicate that the hot water is 'mixing' with the cold water causing a constant running of the hot water? This would solve a couple of things for us. Our water bill has increased almost double, and we've been noticing that our hot water heater is turning on more often than it should.
Is this mixing normal? Is it a setting? Is it a bad valve / cartridge? I only know about the Posi-Temp pressure balanced shower cartridge from all the YouTube I've been watching lately.
TIA!!
Kevin
TIA!!
Kevin
