I have a boiler and my water is not very hot. Some of my bathrooms have somewhat hotter water but even that isn’t as hot as I would expect. I replaced the mixer valve because the water pipe out from it isn’t all that hot to the touch, and it is set to 125F. No change. The hot water is probably around 80F. The boiler temperature is set to 175 and the gauge on the front confirms the water is at this temperature. The pipe from furnace to the mixing valve is hot and so are the input and output to the circulator. I also have two kitchen sinks- one has the not so warm water. The other gets barely a trickle when the hot water is on but both have no issue with the cold water. Additionally, I cannot run a hot water load in my washing machine because it fills so slowly that the washing machine shows error lights that the hot took too long to fill. Any idea?
