We moved to a new house recently. There was a dead recirculating pump installed on a dedicated return line, or at least that's what I thought the line was as it's a line that connects to the pipe that has a drain valve on the water heater. I replaced the pump and everything seems to be working great, however, in certain bathrooms it now takes about 30 seconds to flush out hot water from the cold water line.
My theory is that hot and cold lines must be crossed somewhere that allows mixing. If the pump was installed on the hot water line at the top of the heater, I understand that I need to cross hot and cold lines at the farthest point from the heater, but is this the correct configuration if the pump is installed on a dedicated return line? I looked under all of the sinks to see if at any point lines are crossed, but didn't find anything. I thought the point of a dedicated return line is to avoid having hot water in the cold water lines.
Thanks for any insight.
GP
GP
