Hello everyone...Iam pupman and very new to this forum...I do not know if this is the right place for this subject but I figured hot water --water heater...well you get the idea... My problem is that after running for a minute or two the cool/ cold water turns hot...I do not mean the hose in the sun hot but the kind you can do your dishes and clothes with....and this is true for ALL faucets, showers, tubs and OUTDOOR faucet... There is nothing special about our system... no re-circ lines or pumps, no solar loops or lines too close to other sources of heat...just the basic branch offs for various cold water uses and the branch to hot water heater...have noticed the cold water inlet pipe to water heater is a little warmer than I would of thought normal....
Have read about problems with single handle Moen faucets and cartridge bleed thru and just so happens I have those kind of faucets and showers too, also have two handle kind. ALL with the same problem ...hot water from the cold side....
Can that much hot water bleed thru a cartridge or cartridges to effect the entire house?????? Is there a check valve inside the water heater that may gone out????
I have these question and more....If anyone can give me a hand would sure appreciate it..............
Thanks in advance
pupman...........
Thanks in advance
pupman...........
