Hot Water Everywhere but Master tub
Speedy358
Dec 6, 2024
8
Fort Worth
Hi there, I’m new to this forum so I do apologize if I’m posting incorrectly however I have an issue that I’ve been dealing with for some time now.
The hot water in my master tub decided to stop working. Even though hot water runs perfectly fine throughout the entire house. This is the only place that I can’t figure out what’s going on. My house is fairly new as it was built in 2017. Any thoughts or ideas on what could be causing this? The water pressure is fine, but like I said, but it’s just cold coming out.
You could follow that pipe back to were it tees off and see if there's a valve off, if there's a panel that comes off exposing the hot and cold lines check for closed valves there simple stuff 1st
Look for a mixing valve under the master lavatory……
All of the lines are behind the walls so I wouldn’t have a clue to start.
Like Twowaxhack said, look for one of these mixing valves under a bathroom sink
Could be a cross over connection in the nearby shower as well. But it requires to shut off water at certain fixtures to test this out. Get a plumber who's okay with water variances and troubleshooting this issue.
Let me say this, sometime about a year ago, I increased the water temperature on my hot water heater and I feel like that was about the same time the hot water stopped working in this tub.
Looks like it. Is that on top of your water heater? That wasn’t what you used to turn up the temp on your water a year ago was it?
Yes, it’s on top of the water heater. I’ve never touched that before. When I turned up the water heater temperature, it was on the thermostat at the bottom of the water heater. Also, where that valve is sitting on the other side of the wall is where my master bathroom tub is where the problem is.
