mountainhousing
I just installed a 30 gal. electric bottom fill water heater and an expansion tank in a mobile home. The water comes out hot at all fixtures and with good pressure but when filling up a glass the hot water is cloudy for 15 to 20 seconds. It then clears up. I have bled the lines and even installed a vacuum breaker (as per code for bottom fills) but it still comes out cloudy. The cold side is crystal clear at all fixtures. To make it even stranger when I run the hot water in the tub and fill a glass it is crystal clear. If I run the hot water in the sink right next to the tub it is cloudy. I have tried taking off all the aerators on the sinks but that doesn't help. The mobile home is on city water and has never had this problem.
Any ideas would be welcomed......
Thanks !!!
Thanks !!!
