Horizontal Wet venting that is dry
Levi
Apr 3, 2016
58
I have noticed a trend....many of the issues with my folks plumbing seem to be a misapplication of Horizontal Wet Venting, which is allowed in FL.
1st example, in each bath, he has a 3" standalone vent, which turns horizontal before other fixtures tie in (the other fixtures do not have their own vents). That leaves a short horizontal dry section in the vent. Is that wrong because it is horizontal and dry, and would it be right if it was wet? Theory being that if there was a sink there instead of a dry vent it would wash the pipe?
"The base of the vent shall be washed" makes a lot of sense. Does that appear in Florida code or IPC anywhere?
I BELIEVE that a rolled up flat dry vent is OK under UPC. I am certain that it is not OK under Florida IPC.
Levi, you are correct in your understanding what the intent of the code is.
So I'm hearing the term flat vent and they are not allowed, but in florida horizontal wet vents ARE allowed.
So to clarify, does this look like a horizontal wet vent design......but wrong because the vent goes horizontal before it gets wet
Or does it look like he was trying to do something different altogether like circuit venting. (The lavs each have vents, these standalone vents serve only tub and shower)
It is too late to fix this, just wanting to understand better for future reference in case something fails. If it is compliant, I want to know, if it is not I want to understand why, maybe use that info to compel the GC to warranty the work
