quinnow1
Hi all...first off I would like to say I am glad I found this forum. it is filled with great information it would take me hours to read over.
I own a house built in 1972. All copper lines in the house and we never had a problem ( that I knew of) for water pressure and or flow. About 4 years ago we had a plumber come in and he replaced the water pressure regulator because we had wicked water hammer whenever a faucet or washer was turned off. that cured the problem but the water flow right after installation was kinda low so he cranked it up.
Now I have replaced the water heater because old one is 19 years old and I want to be on the safe side if ever not home for a while. me and a friend checked my water pressure using two diff gauges and both read 105PSI. I thought this was extremely high so I also checked two houses around me...one directly next door and the other across the street, both had same reading at 105PSI. I am sure I do not have any pipe restrictions because many places we cut the pipes they were all spotless inside and besides we have great flow at the high pressure to the point it would knock you over. but when the pressure is reduced the flow sucks bad and upstairs it barely comes out. The regulator that was replaced was a "Watts" 25-75PSI regulator. if the Max range is 75PSI why am I getting 105PSI reading on my gauges? Do I have a bad regulator? I do not hear any pipe knocking ( water hammer) and right now at 105PSI I have great flow but I am worried about damage to the plumbing. Any ideas or help? Thanks.
