Hello,
My question is about what is required for a T&P for a water heater on the second floor of a condo (and general requirements as well). It's about a 30 year-old water heater. It's starting to leak. I plan to have this installed and permitted, but I've been told different things by different plumbers. Can the drain be combined with the T&P for the HVAC coil, or will an entire separate drain be required--and does that drain have to run all the way to grade? I know they will require a drain pan, what else should I expect and what does the code require?
Thank you in advance.
