cottageguy
Hi there,
I was hoping someone knowledgeable will be able to help me fix my plumbing issue. Before I dive into my story, just want to say that I inheritted this mess.
The current issue is the tub basin doesn't drain. It's been draining slowly for a long time, however, I noticed today a 4" stain around the tub basin. Note, our washer drains into the tub basin.
I've sketched out and uploaded some pictures. I'm very handy just need advice on how I could re-plumb this if that is even possible.
I know that a vent stack is need to get air behind the water as it drains. The issue is there is no vent stack.
Also want to mention that the pipe extending to the left I have it capped with a plastic rubber cap. If I remove it with the the tub full, water comes flowing out this pipe.
If someone could maybe sketch I we need to do that would be great or if you feel I should call a plumber I will do that do but I would prefer to the expense knowing that I can cut and glue abs.
Thanks
Thanks
