Hello,
I'm getting new granite countertops/sink and still want a garbage disposal to work. My concern is the current height of the drain pipe going into the wall. My plan is to get a new InSinkErator disposal with a model that has 6" from the bottom of the sink to the center of the exit pipe of the disposal. If I get a 9" deep sink... plus the 6" for the disposal... the exit of the disposal will be exactly 1.75" higher (center of pipe to center of pipe) than the drain pipe going into the wall. Is this high enough? Should I go with an 8" deep sink, and then the exit will be 2.75" higher than the wall drain?
1) is 1.75" higher enough?
2) will another inch (using an 8" deep sink vs a 9" deep sink) make a big difference?
3) what insinkerator (or other brand) disposal do you recommend? (I've heard that the badger series isn't very good... is it definitely worth the money to get an evolution series instead?)
Thanks for your answers!!!
