lseguy
Gas heater. Mfr date is 2011. Installed in my home when the home was built. Model GS675YVRIT. Installed on third (unfinished) level of a three level home.
Was operating fine up until a couple of weeks ago when I could hear the power vent running non-stop. Went up to check and saw LED lights on the control panel. The vacation light on far left, the LED under the yellow arrow, and the Led on the far right were all illuminated. Per the manual, the problem: "Pressure Switch circuit remains open longer than 5 seconds after blower is energized". I also noticed that one of the baffles from the flue, had fallen off/down onto bottom of the hot water heater.
At its current age, decided to have Home Depot come out to give a free estimate on a new hot water heater. Their estimate to replace with another 75 gallon: $3200. (mostly labor, due to third floor level and it being a "2 man job". The technician suggested calling a repair person since the tank itself was still good/no rust, as his company (sub of Home Depot) only did replacements. I did ask if I could save by getting a smaller hot water heater, but he insisted that the size installed by the builder was what they would be required to replace it with. (Another 75 gallon unit)
Decided to try fixing this myself first (not the best idea in hindsight, but thats neither here nor there now):
Followed the guidance to check all tubes/hoses. I did, and all were intact/snug/unblocked. Decided to replace the entire blower motor unit with switch. With the blower motor off, started to carefully lift out the flue. Then realized that due to the ceiling height, impossible to fully remove the flue. I'd need to cut the lines, disconnect, drain, and lay the heater on its side in order to have enough room to remove/install flue. I read online where its not uncommon for the lowest baffle to fall off after years of the heating cycle, and that one missing lower baffle should not be an issue. Is this correct?
Anyways, after replacing the blower, got a different code. (See photo).
So I did some more reading, and I read where its not uncommon for that control unit to fail. So decided to replace that unit. (Yes, expensive way to learn, but cheaper than $3200). I figured if the original gave me 8 years of service, then not a bad spend. (Assuming it solved the problem).
Well it didnt. Installed it earlier today and got the same code. (The code in the photo is listed as ""The Gas control valve/thermostat has detected the air pressure switch circuit is opening repeatedly during one heating cycle".
My question: Is it possible that the one missing baffle from the flue, is causing some sort of issue with pressure detection, thus, triggering the error lights?
And yes, my current plan is to find a proper hot water heater repairman next week to come in and just fix this thing unless there is something Im missing to check.
Thanks
Thanks
