Heating element size help
that unit has 2 4500 watt elements, that is what you should be using
they are not rated by length, but by watt,look on the end of the element where the wires hook up
the wattage is there, it is also on the package it was wrapped in
Good deal Frodo, I was worried longer depth may come too close to other things inside such as the Anode rod or feed tube. I will leave it as is. Thank you for your input.
