scottgibson
Got a downstairs toilet that has been working fine for years recently start acting up. It acts like it is clogged so I use a plunger and have used OTC drain cleaners (lye once and sulfuric acid once). Every time it clears and flushes fine. However here is the weird part: I go back to it later (a few hours or overnight) and now it's clogged again without anybody using it!
So basically it's clogged (without reason), I clear it, it works fine, multiple flushes, wait a little bit and clogged again. When I say clogged I mean the bowl backs up when flushed and it appears like a drain blockage.
I changed the flapper as I noticed it was leaking but this was during my troubleshooting and not before the problem started. No known event led to this.
