I am only posting this here because I am not sure where to post. If there is another forum somewhere for this question please advise and I will go there.
The other day as I was edging around the gas meter in the backyard I inadvertently snapped in two the grounding rod that is attached to the meter. I figured I would just go buy another length of metal pipe and reattach to the main pipe going tothe meter, like the current rod is attached.
Then I began wondering what is the purpose of this rod in the first place and what is it actually grounding at the meter. I've attached a picture showing the meter and, on the right side, is the metal rod I broke that is still attached to the meter pipe via the metal strap (I just temporarily stuck it back in the ground).
Can someone explain if I need to replace this grounding rod? The house was built in 1960 and the fact that I was able to snap the rod in two using an edger tells me the pipe is probably pretty old as well. Thanks to anyone for making me more astute about this.
GG
Houston, TX USA
Can someone explain to me what this
GG
Houston, TX USA
