seldomseenallover
Hello, I would like a bit of additional guidance on this problem. I had a leak coming from my gas hot water heater (40gal). I changed the plastic drain valve to a brass one (that leak stopped), I still had a leak coming from an outside drain pipe next to my outdoor garden hose (on/off valve). Did some research which implied it could be a temp|pressure|relief valve. I changed the temperature pressure relief valve as well (Watts lf100xl). I still have a leak coming from the outside drain pipe. The water bill hasn't increased drastically although I have a steady drip of water from this drain pipe. Any other ideas of a cause/solution?
