Furnace help
ExtraMilePlumbing
Aug 21, 2014
512
87
The other day we lost a job.our most experienced plumber said we dont toch furnaces..well i want to learn.this furnace had a burning flame in the thermocouple that stayid on.even after i turned of the thermostat.and i pulled the plug to the furnace.the flame stayed on .finally i turned of the gas .the flame stoped.then i tryed turning it back on and no luck
Look up the type of furnace you have on line and see if they have a manual.
They usually have trouble shooting guides in the back. For the Basic stuff.
There is a lot of stuff that is not in the manuals though that sometimes comes with experience
I work on a lot of RayPac, American, A.O.Smith commercial water heaters. Not all are the same but many are similar in many ways.
My furnace is old and does not have a pilot safety. It has a standing pilot.
The pilot will stay on if I unplug it and will not automatically shut off if the flame goes out. NO thermocouple. Just to see if I am correct I turned off the gas a couple minutes ago. Yup Just stuck a lighter to it after I turned on gas and it relit. It does have a I think a thermopile that lets the controller/thermostat know it has a pilot flame before it will open the main burner.
works good.
It all depends on how old that heater in ? is. does it have a button on the gas valve that you have to push in to light the pilot manually or is it electronic ignition. If it electronic ignition then I agree with Frodo, If you turned power off and pilot was still on . probably a bad valve . If its a standing pilot that you have to light manually then the power has nothing to do with the pilot flame.
If it has a thermocouple or thermopile then look for a button to push to relight the flame some are in the on/off dial, some are seperate
Thank you guys very much.problem was solved .there was a pilot button i didnt see at first and it turned back on.also found out the flame is always supposed to stay on..thanks
