I live in the great white north, plenty of snow and cold weather. I bought my house new construction 10 years ago and last year during a very cold spell had sewer smell in the house. When temperature got milder, smell went away.
First cold snap this year and same issue. The smell is coming from upstairs bathroom. Main floor has kitchen, second bathroom, garage drain and basement drains, none of these ever smell. When I flush upstairs toilet during these cold spells, I hear the distinct gurgling sound right after the flush, like the water being siphoned, and this sound goes away with milder weather. Quite convinced this vent is freezing up.
I checked attic last year and there are at least 2 vent pipes that go out to the roof. Because of where upstairs bathroom is located, quite sure it does not share venting with other plumbing. Attic is very big, 20 x 28 and very high pitch roof, 20 foot apex in the attic, very well ventilated.
Two options I am considering for my problem. First thought is the vent pipes run close together before exiting the roof, putting a T on each pipe and connecting them together, allowing the upstairs bathroom to use the other vent when it freezes, or using its own when thawed.
Option 2 is to put an AAV on the vent pipe for the upstairs bathroom, installed in the attic. Would either solution be against code, but more importantly, would either solution pose health hazards, or other plumbing issues?
In the summer I could see about having a larger diameter vent pipe, that hopefully would not freeze, put through the roof. Not an option I would like in the middle of our winters and with the high pitch roof I have.
Thanks
Thanks
