I should start by stating that I know very little about plumbing so forgive me for using incorrect terms and any other kind of ignorance that I might present in my question. I did change the flexible water tube from my toilet once and I'm pretty proud of that.
I've been conceptualizing a fully automatic water changing solution for a salt water aquarium that isn't like anything I've found on the internet. It seems most aquarists have a loose idea of what automation really is and perhaps there's a good reason for that, but that's what I'm trying to figure out.
Anyway, my concept would ideally contain a single valve that controls the flow of water between two separate junctions. It would also be great if this valve could be controlled via a motor, but that's another problem for another day and not what I'm asking here. I don't really have much of a way to explain this so I attached a simple diagram of what I mean. The blue is the water flow and the red lines are the flow blockage created by the valve. I assume this could be done more easily with two valves, but a single valve would mean less moving parts which is always a good thing.
I don't know if this exists, if it's common, if it's practical, impractical, or impossible, so I figured I'd ask some professionals what they know. Also, my original idea was to have this valve turn via a motor receiving a signal from another source, but a mechanical alternative might be to have it turn automatically when a certain amount of pressure comes from the clean water supply pipe and then turn back when the pressure drops like a shop door might do. Let me know if that is possible if you have any input on that, as well.
Thanks.
Thanks.
