Hello,
I was wondering if anyone knows how to fix my problem. I need to raise the water level in the bowl after each flush. I replaced the flush valve as the original one was getting caught and allowing water to run. I adjusted the level as high as it can go. I've also adjusted the flush valve mechanism as high as it can go without the tank cover sitting on it. Is there too much water in the tank? It just seems to fill up the tank so quickly that water doesn't have a chance to fill the bowl before the flush valve comes to a stop.
Thanks
Thanks
