ihatefluidmaster
Previously I had a fluidmaster 400, I dont remember if it came with the toilet or if a plumber was called to fix it. Anyways, for the past couple months to a year, it has been acting up, I don't rmember how much in detail, but I do know that of recently (at least 2 months or so), the water in the tank would randomly refill. The most recent issue was the water draining right after being refilled and vice versa. After playing around with everything, I found out that whenever I took the water out of the float cup, everything returned back to normal, until the watrer eventually found it's way back into it and then repeat. Well i ended up buying new one and everything seemed to work as it is supposed to. Until I noticed that the water would drain a little bit, and then refill in a rapid succesion. This drainage/refill pattern never happened with the old fluidmaster. Anyways with a little tampering, I managed to stop it. This is when I realised that something was wrong. Now what the toilet does is it may not refill the water past 1/8/1/10 of the tank. So it will appear to be refilling, but water is also being drained at the same time causing the water level to remain the same or refill very very very very very very very very slowly. And how do I manage to get it working again? I shake the water out of the float cup. It hasn't been up to 2 weeks yet. Not only am i upset that this is a new product, im also mad that my brother (who isn't an idiot), for some reason is never aware whenever the toilet is running constantly and never puts in an effort to figure out what wrong with it because he's too concerned trying to learn every ****ing useless word their is to know in the english vocabulary, meaning water will continously be wasted unless I just happen to hear the toilet. And it's ****ed up because he always uses it .
Why is water continously going into the float cup and giving me this problem?
