Thank you frodo, i want to feed a possibly 199,000 btu tankless at a point
-from meter to it about 140'
-then t off that at about the 90' mark to another smaller tankless on other side of house which would be 170' from T or 260' from meter.
-at about 60' from the T going to smaller tankless I need a T to feed a outdoor grill and maybe some small gas powered lamps
-and eventually i would split off one of those tankless to feed a gas range..
Reason for 2 tankless is my house is really long and distance from furthest in house bathrooms is 140' also installing a outdoor shower thats probably another75 foot farther plus a outdoor sink at outdoor kitchen area. So i have 3 full baths now plus the oudoor area, and in future may add a master suite bathroom with large tub.
- right now from meter to 90' mark where first T will be is 1.25" inch ips yellow pe pipe. Worried i may need to start from meter with 1.5"
- I am fixing to pour some patio areas and need the pipe to go under them and a couple through them, so was thinking i could run 2.5 or 3" grey conduit to allow me to run it under them after they are poured.. and using 3" grey pvc els to allow flexible riser to poke though slabs..?
Thanks for any help and advice.
