First post so sorry if I miss something important!
Recently the hot water has stopped working. The timer still comes on but the boiler doesn't kick in. I had a fiddle and if I turn the central heating on and then off the hot water starts (nothing happens with both on, equally this happens the other way around too)! I had a bit of a read about the issue online and though it was a problem with the mid position actuator (MA1) so I swapped it out for a new one but have the same problem.
The actuator is unlocked in the M position.
What should be my next steps?
