I have a 3 handle tub/shower faucet. Cold side was leaking so I replaced the washer. I also took apart the hot side to check that washer. When I put it back together the stem seemed to stick out farther. The handles won't turn at all. Stuck in on position.
I can see two threads of the white plastic part between the handle and silver cover.
Do I need to screw the stem in more tightly? I am nervous about making it too tight and messing up another part. The YouTube video I used for directions said that making it too tight could damage a $100-$300 part.
Any suggestions? Experience with this?
The water runs warm so both sides are in the on position. Turned it off at the meter.
