Cashews121
My faucet does not shut off when the Spray hose is in use. It does slow somewhat,but does not shut like its supposed to. This is not a new installation,was fine for many years. Any idea what causes this?
google your faucet make and model diverter
Slide #7 up and remove # 5
Take off the spout.
Lift out the diverter and install new one.
Looks pretty simple.
If you are not very mechanical then call a pro.
We like the easy ones now and then.
But # 5 isn't sliding up,,do you twist it? pry it up? don`t want to break it..
should just pull out. They way it works is when the faucet is on there is water pressure to both the hand unit and spout. the hand unit is closed until you push the trigger on it. when water starts to floow to hose the diverter moves and cuts off water to the spout. if you are getting water from both when you use the hand unit is because the diverter is not moving with the flow so it does not cut off flow to spout
