Faucet Install Stuck Nut
diyron
Active Member
Oct 14, 2016
39
Can't loosen a stuck nut on a copper pipe to a shut-off valve under bathroom sink. I've attached some pics. Appears to be green mineral deposits and some grey material stuck around nut.
1. Is a nut for a shut-off valve ever soldered onto a copper pipe or is the hard green and grey material just some build up over time? I'm hoping its a compression type nut.
2. Can I use an oil penetrant on the nut (such as Blaster), and is that okay to use around pipes and water?
Always appreciate the help! Thanks
I'd use PBlaster, then let it sit overnight. I honestly can't fathom how they would even solder those two metals. Try it again tomorrow and I'm sure it will wrench off.
Thanks, havasu and frodo. Really appreciate the help from both of you. I'm going to see this installation through to the end. New to plumbing and have learned a lot from this forum.
We will be here for you. All we ask is that you give us a pic of the finished project for others to learn from.
Have a quick follow-up question. I removed one of the frozen nuts (with a steel brush to grind away built-up mineral deposits, PBlaster and a lot of determination). The compression ring is stuck on the copper pipe and won't slide off. Is my choice basically a compression ring puller, or a dremel? Or is there another way?
Thanks again!
Thanks Matt30. The hacksaw blade worked and rings are off. I've learned it can be a lot harder to remove an old faucet than it is to install a new one. But that's all part of the learning process.
Faucet is installed! Will post pics and what I learned as a diy-er
One last question about the project. Is there a temporary cap that can be placed on the exposed copper water supply pipe from the wall? I ran out of time using a hack saw on the stuck compression ring and needed to turn the water back on. I reattached the old stop-valve and it leaked badly (nothing like turning the water back on downstairs and hearing the sound of a geyser upstairs).
I expect more stuck compression rings on a similar faucet and would like to temporarily cap off the pipe so I can turn the water back on between using a hack saw to remove the badly stuck compression rings.
This site is an amazing resource for people like me who need a little (or a lot) of direction when working on our own plumbing. And I would like to thank all the people who helped me along the way.
