About a year ago I installed a pressure reducing valve on the water line coming in to the house. The incoming pressure was fluctuating between 80 - 150 pounds. The PRV is now set to 55 pounds.
Water pressure on the outside faucet now reads 55 pounds. I then checked the hot water tank pressure at the drain valve on the tank and it was reading up to 110 pounds after the burner ran.
So I decided to install an expansion tank on the cold line feeding into the water heater. It is a Watts 4.4 gallon tank which I have pre-charged to 55 lbs pressure.
After reading the water tank pressure over a period of several days I am getting pressure readings up to 70 lbs while the burner is running.
Is this normal? I was expecting to see the pressure in the hot water tank to equalize with the 55 lbs set on the expansion tank.
Thank you for any insight!
