Needs support.
Maybe a wire on each side of the tank, for even support.
One wire hanging from each side of the rafter.
Is there a catch pan with a plumbed drain, under that heater?
And is the relief valve plumbed to a drain?
Very good.
Will the relief valve discharge into the pan if it leaks or blows?
Your answer makes no sense.
I am asking if the discharge from the temperature and pressure relief valve drain pipe will be caught by the drain pan.
I am asking nothing about the expansion tank or the water heater itself.
Jeff is right on with supporting the tank. Yes, PEX will support the tank when it’s new and operable. However, when the tank’s diagram fails and the tank fills with water, it’s total weight will become something the PEX pipe and fittings may not support.Will this work or do I need to have a stainless strap around the tank with wire hanging it to roof truss? I know PEX is pretty strong but I'm not sure if it can actually hold the expansion tank. Your thoughts?
I have to ask ...... why do folks install these expansion tanks hanging down where if they fail & fill with water the weight at 8 pounds+ per gallon tears the pipes down ?
If these tanks were installed "on top" with the threads on the bottom they would not fill up even if the internal bladder failed and would never jeopardize the piping.
I have a better question.I have to ask ...... why do folks install these expansion tanks hanging down where if they fail & fill with water the weight at 8 pounds+ per gallon tears the pipes down ?
