Eccotemp 20L 6-GPM 150000-BTU Outdoor Liquid Propane Tankless Water Heater
Apr 13, 2021
18
north carolina
Went to install it, all is well except the GAS Inlet has straight male threads that looks like the connection need a rubber washer.
However I need to connect a black pipe to it, with a drip leg and a TEE . The Short Yellow CSST will connect to the TEE and connect to the shut off valve
which is connected to the main gas supply. The Inlet is 3/4 and the supply is 3/4. Is there a adapter that can connect to the male threads on the inlet and
allow me to connect the 3/4 Black Pipe to the adapter
Not normal plumbing in the USA. Contact mfr...
Instructions should tell...
