This may be the dumbest question ever asked here but I'm just trying to DIY and got stuck.
I'm trying to install a tub filler and the part that is screwed to the copper fitting leaks. I think I did not turn it tight enough but the design of the tub filler is such that the part must be turned to an exact upright angle. If I try to turn harder I won't make a full circle but if I stop turning earlier it ends up not tight enough and it leaks....... I tried many times by starting from a different angle but it looks like that it always latch on the same point so I end up with the same situation every time...... Any suggestions? Any help is very much appreciated!
TK
TK
